Prokiller Posted October 31, 2014 Report Share Posted October 31, 2014 Welcome fellow SN95 sourcerer's to a wizardly Ride of the Month voting! No this isn't a Harry Potter themed post where you'll see flying cars....well then again it kinda is. These cars do fly, but on the ground. And like any true race car they do it so much so that they breakdown. A few of our contestants are currently in the brewing stage of an even great potion for power. So wave your magic wand over the best race car for a speedy assembly so that they can get back on the broomstick and fly down the track or around some orange candy corn in a parking lot. F8L GTPerformance-Mark 8 short blockPorted PI heads Custom ground long duration cams Vic Jr intakeCoyote injectorsAEM E85 340 pumpSS long tubesCustom mid pipe w/ custom mufflersProfessional products plenum & 70mm tb Custom air intakeFaceplated 365031 spline Moser axlesCobra Diff Interior-Grant steering wheelCustom radio deleteAir bag deleteCustom rear seat deleteOil pressure and water temp gaugesMonster tachPro 5.0 shift handle with Jegs pistol grip Exterior-Spoiler deleteTinted headlights and tails Mach 1 grille delete and chin spoilerSponsorship decals Wheels- Jegs sport stars 15x10 rear26x10.5 MT ET drags15x4.5 frontMT ET Front Drags Suspension-Front stock with 4cyl springs Strange strutsRear baseline relocated uppersTeam Z double adjustable lowersCut stock rear springs BADASS03SVT Engine:L&M built Teksid, stock bore / stroke (281)L&M custom cams / heads / pistons (10.5:1 CR)Stock crank, Oliver rods, ARP hardwareWhipple 4.0 @ 25psiSCT tuned by Jon Lund (stock ecu)Kooks 1-7/8 headersKooks 3" x-pipe & mufflers Drivetrain:Frank Lupo C4 & converterB&M Hammer shifterDynotech aluminum driveshaftsra 8.8 w/ 3.55sStrange spool / 33 spline axlesStrange brakes all around Suspension:MM caster camber platesUPR coil over kitUPR K-member & a-armsUPR upper & lower control armsStrange strutsAfco shocks Exterior:VIS Carbon Fiber hoodClear corner lightsBullit side scoopsCarbon Driven trunk lid / spoiler Interior:Kirkey seatsScott Rod rear seat deleteScott rod trunk floorAutometer gaugesDMC Racing 10 point cage and sub frames Wheels:Billet Specialties Comp 5 wheels15x3.5 & 15x10Mac Fab beadlocksMickey Thompson ET Street Pro MiscDynotune Nitrous kitChiseled IC water tank Best ET - 8.33 @ 163 w/ a 1.22 60' Musturd Performance: Dart iron eagle 331 Comp nx 282hr cam Edelbrock performer rpm heads 1.60/1.90 Polished victor 5.0 intake manifold Vortech s trim cog driven at 15#'sCsr electric water pump 42lb injectors 90mm svo throttle body Pro m 92 mafBBK long tube headers BBK off road x pipe Flowmaster delta flow cat back G-force T5 transmission Act 6 puck clutchB&M pro ripper shifter Frpp aluminum drive shaft Built 8.8 with 31 spline auburn posi and moser 31 spline axles Frpp 3.73 gears Suspension:Upr k member and a arms Upr caster camber plates Upr Coilover kit Upr pro series rear suspension Strange 10 way shocks and struts Through floor subframe connectors Cobra brakes front and rear 13" front 11.65 rear Interior:Acura rsx seats Autometer sport comp monster tach Triple gauge pod with matching boost ,water temp and oil pressure Hurst sidewinder shifter ball Maximum motorsports 6pt cage Exterior: Oem cobra hood Oem cobra front bumperOem cobra rear bumper Shave trunk including 3rd brake light with kill switch mounted in key hole Shaved passenger door lock . Wheels: Bogart D1015x3.515x10 Mickeythompson ET streets 28x12.50 iRoush Engine: (388rwhp/385rwtq N/A)MMR 600 Short BlockMHS Stage 3 Ported HeadsMHS Stage 4.5 Bullet CamsSteeda Underdrive PulliesAccufab PlenumRoush 75mm Throttle BodyJLT Ram Air IntakePort Matched OEM Intake ManifoldMMR-Moroso Oil/Air SeparatorEGR DeletePCV DeleteMoroso Coolant OverflowOdyssey PC-680 Battery w/ aluminum mountFRPP 42# Injectors90mm Lightning MAF2004 Terminator Fuel Tank w/ PumpsMac Longtube HeadersMac Catted H-PipeDynomax Super Turbo Side Exit ExhaustT45 Source Dog Ring T45Fidanza Aluminum FlywheelExedy Mach 500 ClutchSteeda Firewall AdjusterSteeda Adjustable Clutch CableSteeda Quick Release QuadrantFRPP Aluminum DriveshaftWelded 8.8 Axle Tubes31-Spline Torsen T2-R DifferentialTen Factory 31-Spline AxlesStrange Differntial GirdleFRPP 3.73 Gearse85 Tune Chassis & Suspension:Maximum Motorsports K-MemberMaximum Motorsports MM3 DampersMaximum Motorsports Forward Offset A-ArmsMaximum Motorsports Front Coilover KitMaximum Motorsports C/C PlatesMaximum Motorsports Strut Tower BraceCustom Front End Alignment for Autocross2000 Cobra R Steering Rack30mm Front Sway BarMaximum Motorsports Solid Steering Rack BushingsMaximum Motorsports Bumpsteer Kit (Cycled Bumpsteer out)Maximum Motorsports 4-Point Roll BarRoush Subframe Connectors (Welded In and tied to roll bar)Kenny Brown Jacking RailsMaximum Motorsports Rear Coilover KitFully Torqued Racing Watts LinkBTM AutoSport Offset 3-LinkWild Rides Battle Box ReinforcementsMaximum Motorsports XD Lower Control ArmsKenny Brown Anti-Squat BracketsMaximum Motorsports Adjustable Rear SwaybarRoush Pinion SnubberFTR 14" Working Man's Brake KitPorterfield R4-S Brake PadsSpeed Bleeder Kit Interior:BTM AutoSport-Bimarco Grip SeatG-Force 6-Point HarnessRoush Gauge Cluster with custom mounted Autometer Oil Pressure Gauge in ClusterBTM AutoSport Progressive Shift LightFlorida 5.0 Radio Delete PanelsBTM AutoSport HVAC Delete Panel w/ AFR+OBD-II Gauge MountsBTM AutoSport Passenger Airbag DeleteMOMO Steering HubNRG Quick Release v2.0OMP od/1990/nn Steering WheelPLX DM-5 Wideband GaugePLX DM-100 OBD-II GaugeRoush Short Throw ShifterGutted Dash, Doors, and TrunkRemoved Sound Deadening, insulation, etc. Exterior:Roush Stage 3 Front BumperBTM AutoSport Front SpoilerMaier Racing Rear SpoilerFTR Spoiler RodsMaier Racing Fender Flares (Cut and redone by BTM AutoSport)Steeda Q400 HoodMoroso Hoods PinsRoush Side SkirtsRoush Rear ValancesRoush Side Exit Exhaust SystemFTR Tow HookSCF Carbon Fiber Wiper CowlHeadlight IntakeHIDmasters 6000k Foglight KitMirrored Finish Radiator PanelMoroso Extended LugnutsXXR 531 18x11 Wheels315/30/18 Hoosier A6 Tires Cast your Vote!!! Link to comment Share on other sites More sharing options...
Blackmage Posted October 31, 2014 Report Share Posted October 31, 2014 Damn, narrowed to two cars that are just over the top. but which one.... Link to comment Share on other sites More sharing options...
Prokiller Posted October 31, 2014 Author Report Share Posted October 31, 2014 apologies go out to @F8L GT for putting his interior pic twice. his engine shot is now up in all it's glory. Link to comment Share on other sites More sharing options...
Alex302 Posted October 31, 2014 Report Share Posted October 31, 2014 wow i wish i could vote for to cars very tough this month Link to comment Share on other sites More sharing options...
95riosnake Posted October 31, 2014 Report Share Posted October 31, 2014 I had to go with @BADASS03SVT The damn thing is blazing fast, and is a really great looking car to boot. I haven't seen many 8 second cars that have smoothed, detailed engine bays and mostly complete interiors... most cars that fast are a gutted jungle gym with a seat. This car is the best of both worlds IMO. Link to comment Share on other sites More sharing options...
BADASS03SVT Posted November 2, 2014 Report Share Posted November 2, 2014 I had to go with @BADASS03SVT The damn thing is blazing fast, and is a really great looking car to boot. I haven't seen many 8 second cars that have smoothed, detailed engine bays and mostly complete interiors... most cars that fast are a gutted jungle gym with a seat. This car is the best of both worlds IMO. thanks man. Its how Ive always wanted the car. Sure I could gut it and drop 50lbs but then it wouldnt be sexy as hell!! Link to comment Share on other sites More sharing options...
Steve-Oh Posted November 2, 2014 Report Share Posted November 2, 2014 Vote cast! @Prokiller , well done once again! Link to comment Share on other sites More sharing options...
Det_Riot Posted November 3, 2014 Report Share Posted November 3, 2014 voteddd! such a hard decision as each car was unbelievable in its on right! Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted November 3, 2014 Moderators Report Share Posted November 3, 2014 I had to go with @BADASS03SVT The damn thing is blazing fast, and is a really great looking car to boot. I haven't seen many 8 second cars that have smoothed, detailed engine bays and mostly complete interiors... most cars that fast are a gutted jungle gym with a seat. This car is the best of both worlds IMO. My sentiments exactly! Link to comment Share on other sites More sharing options...
Prokiller Posted November 3, 2014 Author Report Share Posted November 3, 2014 I think it's okay to close this down so early. seems like we have a clear winner this month. voting closed. Link to comment Share on other sites More sharing options...
