kellogg Posted November 18, 2014 Report Share Posted November 18, 2014 A brief timeline..always a work in progress ...except the timeline posted newest to oldest top to bottom Link to comment Share on other sites More sharing options...
Blackmage Posted November 18, 2014 Report Share Posted November 18, 2014 Very nice looking car man. Got a mod list on that bad boy>? Link to comment Share on other sites More sharing options...
kellogg Posted November 18, 2014 Author Report Share Posted November 18, 2014 As of right now its a 357 ci Windsor 8.5:1/9:1 comp(not exactly sure as I've just had heads resurfaced..trick flow heads.custom ground hyd flat tappet bullet cam.-8 fuel delivery.single plane intake bunged for fuel injectors. Billet flywheel kevlar clutch..currently on 4th T5 transmission.alum. driveshaft 3.73 rears. 315 drag radials..and I'm putting together a twin turbo set up for it now Link to comment Share on other sites More sharing options...
Det_Riot Posted November 18, 2014 Report Share Posted November 18, 2014 Nice looking good man!! I have to ask, you never had an 00r hood on your car did you?Nice looking good man!! I have to ask, you never had an 00r hood on your car did you? Link to comment Share on other sites More sharing options...
kellogg Posted November 18, 2014 Author Report Share Posted November 18, 2014 No never had the 00 R style..I have had two of the 4" cowl r style tho..(as I had a latch failure at around 100 mph..also lost the winshield, pass. Mirror, sail panel, and fender on that one) Link to comment Share on other sites More sharing options...
Det_Riot Posted November 19, 2014 Report Share Posted November 19, 2014 No never had the 00 R style..I have had two of the 4" cowl r style tho..(as I had a latch failure at around 100 mph..also lost the winshield, pass. Mirror, sail panel, and fender on that one) Lol okay I bought my current hood from a guy who now has a cervinis single step. Been there done that with the hood failure lol not fun Link to comment Share on other sites More sharing options...
kellogg Posted November 19, 2014 Author Report Share Posted November 19, 2014 I may have to switch the cervinis back out for my 4" cowl with these turbos for clearance..I'll cross that bridge when I get there I guess..as far as when the hood came off I have haggerty insurance..they're great to work with Link to comment Share on other sites More sharing options...
Steve-Oh Posted November 19, 2014 Report Share Posted November 19, 2014 That's a pretty sick setup! Link to comment Share on other sites More sharing options...
Prokiller Posted November 19, 2014 Report Share Posted November 19, 2014 sweet setup. love the center intake path. Link to comment Share on other sites More sharing options...
kellogg Posted November 19, 2014 Author Report Share Posted November 19, 2014 its coming along. be done by spring..problem im running into now is clearance with drivers side down pipe and brake booster. the cobras have a pretty large vacuum booster on the 94-95s. and i dont believe i have enough room length wise to switch to hydro boost. so im looking at using a MM manual brake conversion..any body try this? any input? Link to comment Share on other sites More sharing options...
SublimeRT Posted November 22, 2014 Report Share Posted November 22, 2014 Sweet car man. I like it. That Cervini's smooth cowl is one of my favorites. I've always really liked those DD '95 Rs too. Of course I have the tried and true R58 Cobra Rs on my car, so I'm a bit biased. I do have the MM Manual brake conversion in my '94 Cobra, though I have not driven the car with it, so I might not be of much help if you're looking for driving impressions, but it's very high quality and lots of extra room in the bay. I could get some pics for you though if you're interested in seeing how much room it gives. Link to comment Share on other sites More sharing options...
kellogg Posted November 22, 2014 Author Report Share Posted November 22, 2014 I'd be interested in some pics..I have emailed MM about my setup and what they recommended for a master cylinder and never got a response Link to comment Share on other sites More sharing options...
Sleeperstang1994 Posted November 23, 2014 Report Share Posted November 23, 2014 i can always get on board for a pair of turbos! looks nice Link to comment Share on other sites More sharing options...
SublimeRT Posted December 2, 2014 Report Share Posted December 2, 2014 That's weird they haven't got back with you on the master cylinder. They are usually pretty good about answering emails. I believe they recommend the stock Cobra 15/16" bore master cylinder though. I think an older Ranger master cylinder has the same diameter bore but the lines exit the opposite side of the unit if you want more room on the engine side, though I can't remember what years exactly. Here's a few pics I took. It sticks out about 8.25" and is about 5" from the valve cover. Link to comment Share on other sites More sharing options...
kellogg Posted December 2, 2014 Author Report Share Posted December 2, 2014 yea.. i have yet to get a reply from them..thanks for the info and pics..that helps a lot.. have you had a chance to try out this system yet. i was curious about the pedal effort on the factory power master cylinder(without booster) vs. getting one from a non power assist car/truck. i would think you might be better off sizing the master cylinder to system to get more pressure with less effort( although i dont know the formula for it). Link to comment Share on other sites More sharing options...
kellogg Posted December 3, 2014 Author Report Share Posted December 3, 2014 Got one header wrapped tonight.if u guYs ever done this or put up fiberglass insulation u know I'm miserably itchy right now Link to comment Share on other sites More sharing options...
Steve-Oh Posted December 3, 2014 Report Share Posted December 3, 2014 Take a cold shower not a hot one, what I was told and seems to work after I've handled insulation. Link to comment Share on other sites More sharing options...
Det_Riot Posted December 3, 2014 Report Share Posted December 3, 2014 Take a cold shower not a hot one, what I was told and seems to work after I've handled insulation.Steve-oh also just gets off to the thought of full grown men taking freezing cold showers.... Troubled, troubled man. Link to comment Share on other sites More sharing options...
kellogg Posted December 3, 2014 Author Report Share Posted December 3, 2014 Steve-oh also just gets off to the thought of full grown men taking freezing cold showers.... Troubled, troubled man.. Haha In that case. I just turned off all the heat.I've opened up all the doors and windows in my house..it's snowing outside. Got the shower on full cold. Standing in a bucket of ice. Drinking a big gulp frozen slurpee Link to comment Share on other sites More sharing options...
Det_Riot Posted December 3, 2014 Report Share Posted December 3, 2014 . Haha In that case. I just turned off all the heat.I've opened up all the doors and windows in my house..it's snowing outside. Got the shower on full cold. Standing in a bucket of ice. Drinking a big gulp frozen slurpeeLmaoooo [emoji23] Link to comment Share on other sites More sharing options...
Steve-Oh Posted December 3, 2014 Report Share Posted December 3, 2014 Lol, set myself up for that one! Link to comment Share on other sites More sharing options...
kellogg Posted December 3, 2014 Author Report Share Posted December 3, 2014 haha im still waiting...this back aint gonna scrub itself Link to comment Share on other sites More sharing options...
Det_Riot Posted December 3, 2014 Report Share Posted December 3, 2014 haha im still waiting...this back aint gonna scrub itselfFunny thing about his back..... It's located on his cock. Link to comment Share on other sites More sharing options...
Steve-Oh Posted December 3, 2014 Report Share Posted December 3, 2014 LMFAO! Link to comment Share on other sites More sharing options...
Blackmage Posted December 3, 2014 Report Share Posted December 3, 2014 Woot! Go get em @Steve-Oh! Link to comment Share on other sites More sharing options...
Det_Riot Posted January 3, 2015 Report Share Posted January 3, 2015 Any more progress now that the holiday season is over?? Link to comment Share on other sites More sharing options...
kellogg Posted January 5, 2015 Author Report Share Posted January 5, 2015 ill be back on it soon.. almost done with a HGTV project i got going on in my basement. Link to comment Share on other sites More sharing options...
Det_Riot Posted January 5, 2015 Report Share Posted January 5, 2015 ill be back on it soon.. almost done with a HGTV project i got going on in my basement.feel free to share that too! As you can see we appreciate build threads of all types Link to comment Share on other sites More sharing options...
kellogg Posted January 8, 2015 Author Report Share Posted January 8, 2015 ill get some pics this weekend. im staining and sealing a concrete floor. if youve ever seen it...hopefully it turns out good Link to comment Share on other sites More sharing options...
95opal Posted January 8, 2015 Report Share Posted January 8, 2015 ill get some pics this weekend. im staining and sealing a concrete floor. if youve ever seen it...hopefully it turns out goodthat's what I do for a living lol Link to comment Share on other sites More sharing options...
kellogg Posted January 8, 2015 Author Report Share Posted January 8, 2015 Any hints tips tricks? im using H and C concrete acid stain and sealer? Link to comment Share on other sites More sharing options...
