Tabres Posted March 28, 2015 Report Share Posted March 28, 2015 Has anyone got a solution to fix the vibration that develops with the button on the e-brake handle in these cars? Mine is starting to slowly drive me insane. Link to comment Share on other sites More sharing options...
Steve-Oh Posted March 28, 2015 Report Share Posted March 28, 2015 Can't stand this myself. Never actually took the handle apart to see what it's all about. Link to comment Share on other sites More sharing options...
ttocs Posted March 28, 2015 Report Share Posted March 28, 2015 vibrating e-brake button?! never heard it or heard of it. Link to comment Share on other sites More sharing options...
Supporting Member fiveohwblow Posted March 29, 2015 Supporting Member Report Share Posted March 29, 2015 Was the worst on my fixbody. Hated that. In for solution for future mustang problems Link to comment Share on other sites More sharing options...
Ferocious Posted March 29, 2015 Report Share Posted March 29, 2015 Wrap the button in electrical tape and push the tape as far down as you can. I've had the same tape on for 3 years... no vibrations. Link to comment Share on other sites More sharing options...
SublimeRT Posted March 29, 2015 Report Share Posted March 29, 2015 ^^+1 did that to my car, worked like a charm. Link to comment Share on other sites More sharing options...
Tabres Posted March 29, 2015 Author Report Share Posted March 29, 2015 So it's as simple as just yanking the actual e-brake handle off (they just pull off, right?), wrap it, then re-install the handle? Link to comment Share on other sites More sharing options...
Ferocious Posted March 29, 2015 Report Share Posted March 29, 2015 So it's as simple as just yanking the actual e-brake handle off (they just pull off, right?), wrap it, then re-install the handle?I didn't pull mine out. I just wrapped whatever was exposed of the button with the ebrake on and was done with it. Link to comment Share on other sites More sharing options...
SublimeRT Posted March 29, 2015 Report Share Posted March 29, 2015 I didn't take anything apart either. Just slid some tape down between the button and handle as far as I could so it wasn't exposed. Link to comment Share on other sites More sharing options...
SublimeRT Posted March 29, 2015 Report Share Posted March 29, 2015 I looked real quick on Google to see if anyone had some pics that would show it better.... didn't really see anything helpful. I saw someone suggested using a piece of heat shrink tubing instead of electrical tape though and thought that is a good idea too if you can find an appropriately sized piece. Maybe just put a little dab of glue down on the button then slide the heat shrink down it, rather than try to shrink it normally. Link to comment Share on other sites More sharing options...
Tabres Posted March 29, 2015 Author Report Share Posted March 29, 2015 Gotcha. I'll mess with it a bit and see what happens. Thanks for the suggestion, gentlemen. Link to comment Share on other sites More sharing options...
ttocs Posted March 29, 2015 Report Share Posted March 29, 2015 I would assume it points to a bigger problem of something out of balance or something? Like I said I have never had it be a problem in my car. Link to comment Share on other sites More sharing options...
Det_Riot Posted March 29, 2015 Report Share Posted March 29, 2015 I would assume it points to a bigger problem of something out of balance or something? Like I said I have never had it be a problem in my car.Out of balance? Wut? Link to comment Share on other sites More sharing options...
Tabres Posted March 29, 2015 Author Report Share Posted March 29, 2015 I'm not sure what would be out of balance to cause the plastic button in the e-brake handle to vibrate. I'm guessing it's just due to production tolerances with a plastic button in a mass produced, 20- year-old Ford - in my case in a car that is really stiffly sprung and has no rubber bushings left anywhere in the suspension. Link to comment Share on other sites More sharing options...
slow90coupe Posted March 30, 2015 Report Share Posted March 30, 2015 Electrical tape mod ftw. Solved the problem in mine instantly. Link to comment Share on other sites More sharing options...
Blackmage Posted March 30, 2015 Report Share Posted March 30, 2015 mine was loose as well, i just lived with it :shrug: Link to comment Share on other sites More sharing options...
Alex302 Posted March 30, 2015 Report Share Posted March 30, 2015 Ive had my car for years and it drives me crazy im trying the tape thing tomorrow. Link to comment Share on other sites More sharing options...
Tabres Posted April 1, 2015 Author Report Share Posted April 1, 2015 I wrapped mine in tape the other night. Haven't gotten a chance to drive it yet and see the result because the registration expired yesterday. Never got my renewal notice, I'm guessing because I never updated the address on my license when I moved 2 years ago. Going to make the trip to the DMV tonight after work. Dreading it... Link to comment Share on other sites More sharing options...
Dysturbed87 Posted April 1, 2015 Report Share Posted April 1, 2015 Another option is to try an oring. May or may not work, but worth a shotSent from my DROID RAZR using Tapatalk Link to comment Share on other sites More sharing options...
Tabres Posted April 3, 2015 Author Report Share Posted April 3, 2015 Just reporting back. Was able to take the car out last night and the tape trick worked perfectly. Thanks for the suggestion everyone! Link to comment Share on other sites More sharing options...
GearGambler Posted April 29, 2015 Report Share Posted April 29, 2015 I can't wait to try this. Thanks everyone for contributing!!! The button vibration is getting to the point of insanity! Link to comment Share on other sites More sharing options...
95riosnake Posted April 29, 2015 Report Share Posted April 29, 2015 Another option would be a piece of gloss black heat shrink that is big enough to fit over the button, then trim it to length, slip it on and hit it with a heat gun. Something like this: https://www.wirecare.com/product.asp?pn=WC03865633 Link to comment Share on other sites More sharing options...
Tabres Posted April 29, 2015 Author Report Share Posted April 29, 2015 Another option would be a piece of gloss black heat shrink that is big enough to fit over the button, then trim it to length, slip it on and hit it with a heat gun. Something like this: https://www.wirecare.com/product.asp?pn=WC03865633 It's interesting you posted this suggestion today. Literally just last night I pulled the tape off of mine and put a piece of heat shrink that I had laying around on it instead. The tape did the job fine but was getting kind of nasty as I used the brake while working on the car with dirty hands. With the heat-shrink there is no sticky residue for this to happen. Link to comment Share on other sites More sharing options...
GearGambler Posted May 1, 2015 Report Share Posted May 1, 2015 Good suggestions. Thanks guys! Link to comment Share on other sites More sharing options...
