Prokiller Posted March 31, 2015 Report Share Posted March 31, 2015 Funny enough that i'm sitting on the ground writing this today. On another business trip down to VA and all the seats with available power sources are taken. So i get cozy on the ground, just like our contestants this month (see what i did there?). Seems one of the pursuits of speed is to be so close to the ground that hitting a pebble could take your front bumper off. I think most of us can agree that it looks amazing. So this month we honor the folks who take this mentality to practicality. Some cars be so low they take the wings right off a fly's asses. Ferocious exterior:- Black housing headlights- Depo black diamond corners- Yellow foglights- Chin spoiler- Custom front splitter- Custom side splitters- Custom rear diffuser- S281 spoiler- Red calipers- Gold bumper inserts- Silver 4.6L badges- 3" carbon fiber antenna- Wiper delete- 5% & 20% tint- 18"x3.5" exhaust tips- Gold tuner lug nuts interior:- Red gauge cluster lights- Red map lights- Red HVAC controls- JVC audio headunit- Dual gauge pillar pod- Oil pressure gauge- Water temperature gauge- Black/red suede shift boot- Red Procar drifters- CDC light bar - Mac cold air intake performance:- Mac 75mm throttle body- Trick Flow plenum- UPR off-road x-pipe- SLM LM1 resonators- PI intake- Spectra premium radiator- Walbro 155 lph fuel pump- FRPP high performance spark plugs - 4:10 gears drivetrain:- T-45 swap- Ford Racing clutch fork- Steeda short throw shifter- Steeda double hook quadrant- SR adjustable clutch cable- King Cobra style clutch - Strange front coilover kit suspension:- Strange 10-way adjustable struts- QA1 10" 300lbs springs- J&M caster camber plates- Revo Technica camber kit- SVE rear lowering springs- Rear isos removed- Strange 10-way adjustable shocks- UPR rear coilover mounting brackets- J&M lower control arms- MM pinion snubber- Rear cobra sway bar wheels/brakes:- 17x9 03/04 polished cobra rims- Kumho ASXs (245) & kumho XSs (295)- 3/4" rear spacers- 1/2" front spacers- Kinetic cross drilled & slotted rotors- Powerstop ceramic brake pads 1SlammedGT Exterior mods:Trufiber Carbon fiber 3 inch cowl hood.Carbon Driven carbon fiber trunkCarbon Driven carbon fiber terminator wing.Maier Racing fender flaresCarbon Driven carbon fiber splitterCarbon Driven carbon fiber side skirtsCarbon Driven carbon fiber side scoopsCarbon Driven carbon fiber fog light bezelsMaier Racing carbon fiber splitterOEM 04 cobra front and rear bumpers03-04 cobra mirrorsCarbon Driven carbon fiber cowl panelInterior mods:Carbon Driven carbon fiber A pillarsCarbon Driven carbon fiber radio bezelCarbon Driven carbon fiber shifter bezelCarbon Driven carbon fiber dual gauge clusterCarbon Driven carbon fiber arm rest coverCarbon Driven carbon fiber door pullsCarbon Driven carbon fiber door cupsAll black dash and interior swapTMI Products R 500 all black with carbon fiber stripes front and back.ACC Mats all black carpet with matching floor mats.CDC light barKenwood double din head unitCarbon Driven gauge cluster overlayLED lightning by Diode DynamicsEngine Mods:Paxton Supercharger 1200 STTrick flow Street heat intake manifoldBBK 70mm throttle bodyAnderson power pipeJLT Performance dual flat black oil separators. 90mm Lightning mafMac off road X pipeMac full cat backMoroso Flat black coolant tankMoroso PS flat black tankForged internalsAll flat black engine bayFront mount intercooler flat blackSuspension mods:Rennen Forged R5 19x11 front and 19x13 Rear extreme concave stepped lip 3 piece wheels. Cobra calipersR1 Concept Custom engraved RotorsAir Ride Equipment Air ride kitToyo Proxes T1 Sport 295-30-19 front and 325-30-19 rear tires.All manual air ride set up. Front and back only. Viair Corp 444cc dual flat black air compressors.Audio: Kenwood double din head unitAlpine door and rear speakersEpicenterAlpine Mono block Amp(2) Rockford fosgate 10 inch subs. Kyle5.0 Exterior:Xenon front lipCarbon fiber GT wingBig County Labs uprights96-98 Tail LightsCobra Head LightsClear CornersKonig SSM's 18x9/18x10235/40/18 Front295/30/18 RearRoof wrapped in black vinyl20% Tint all aroundSpoilerKing roof spoilerColor Matched MirrorsShorty Antenna Interior:Black carpet98 center consoleRear seat delete kit01-04 Double din radio swap with Kenwood touch screen head unitBlue LED dash/hvac lightingJack Roush autographed shifter bezelBlack interior swap Suspension Modifications:Eibach Prokit Springs with 1 coil cutTokico Illumina front strutsLakewood drag rear shocksMaximum Motorsports Caster/Camber platesMaximum Motorsports Full Length Subframe ConnectorsMaximum Motorsports Adjustable Lower Rear Control Arms Engine/Performance Modifications:FRPP 3.73 Rear Gears w/ New BearingsBBK O/R H-pipeMagnaflow Magnapack Mufflers into stainless 2.5" tailpipesBBK CAIMGW Short throw shifterMSD cap Maximum351 Performance: -OEM 1994-1995 Cobra intake manifold-MegaSquirtPNP gen. 2 ECU-ProCharger D1 with 4" pulley-ProCharger front mount intercooler-BBK 70mm throttle body-BBK strut brace-Siemens 72lb injectors-TiAL Q blow off valve-MSD 6A ignition-MSD TFI coil-MSD spark plug wires-AEM 320LPH fuel pump-Misimoto radiator-UPR off-road x pipe-Flowmaster American Thunder series mufflers-Odyssey PC680 battery with custom box-K&N cone filter directly on the ProCharger-Dyno tune by SQC tuning in Albuquerque, NM Suspension/Chassis: -BC Racing BR type front coilovers with built-in camber plates-Granatelli tubular front control arms-Maximum Motorsports bump-steer kit-UPR height adjustable rear coilovers with 10", 175lb springs-UPR rear drop brackets-Eibach rear sway bar-Maximum Motorsports XL subframe connectors Exterior: -American Muscle Mach 1 style chin spoiler-Cobra headlights-Black tail lights-Black bumper inserts-Big Country Labs Atmosphere Demolisher wing-Custom antenna delete Interior: -Autometer dual gauge instrument bezel-Autometer steering column gauge pod-Autometer Z-series boost gauge-Autometer Z-series oil temperature gauge-AEM UEGO wideband-Steeda Tri-Ax short throw shifter-Corbeau Forza driver seat-American Muscle Bullitt style pedal covers Wheels/Tires: -3 piece SSR Vienna EV built by VRwheels, 19x9.5 +11 and 19x11 +5, with step lip-Yokohama S-Drive 225/35 and 255/30 Let the best stance win!!! Link to comment Share on other sites More sharing options...
htm281 Posted March 31, 2015 Report Share Posted March 31, 2015 how do i enter? (even though i do not have many mods lol!) Link to comment Share on other sites More sharing options...
95riosnake Posted March 31, 2015 Report Share Posted March 31, 2015 how do i enter? (even though i do not have many mods lol!) People nominate members' cars that meet the month's criteria in a nomination thread. The members with the most nominations move onto voting. Here was the nomination thread for this month (now closed): http://www.sn95source.com/topic/5207-april-rotm-nomination-thread/?hl=%2Bapril+%2Brotm Link to comment Share on other sites More sharing options...
htm281 Posted March 31, 2015 Report Share Posted March 31, 2015 People nominate members' cars that meet the month's criteria in a nomination thread. The members with the most nominations move onto voting. Here was the nomination thread for this month (now closed): http://www.sn95source.com/topic/5207-april-rotm-nomination-thread/?hl=%2Bapril+%2Brotm oh so that's how it works! thanks, perhaps i'll see next what happens for next months ride of the month Link to comment Share on other sites More sharing options...
Tony Posted March 31, 2015 Report Share Posted March 31, 2015 am i not seeing the poll lol? my pc fn up again Link to comment Share on other sites More sharing options...
Steve@CJPP Posted March 31, 2015 Report Share Posted March 31, 2015 am i not seeing the poll lol? my pc fn up again fixed. Link to comment Share on other sites More sharing options...
Sleeperstang1994 Posted March 31, 2015 Report Share Posted March 31, 2015 well this is the first month in a few i have absolutly no idea who to pick! anyone interested in throwing a few bejamins my way might help me make my mind up! but seriously hard choice Link to comment Share on other sites More sharing options...
stang232 Posted April 1, 2015 Report Share Posted April 1, 2015 4 cars, 4 different styles. We will see what kind of stance look best at SN95. I know that I should look at the whole cars, but I only see wheels, tyres, fenders and I measure gap between them.In this voting, please change engine pics on side view pics Link to comment Share on other sites More sharing options...
1SlammedGT Posted April 1, 2015 Report Share Posted April 1, 2015 I'm honored to be nominated for ROTM. Thanks to everyone who nominated my car and to those who voted for me. Let the best car win. Link to comment Share on other sites More sharing options...
95riosnake Posted April 1, 2015 Report Share Posted April 1, 2015 Still torn on who to vote for, I'm gonna force myself to vote before the end of the day lol. And LOL at the guy getting all upset about stanced/slammed mustangs on the post I put up on our IG page lol. Don't worry though, his bolt on sn with bullitts would give you all a run for your money, lol smh. Link to comment Share on other sites More sharing options...
Tony Posted April 1, 2015 Report Share Posted April 1, 2015 lmao i just read the comments wow cool to see him getting his ass handed to him by open minded mustangers though @1SlammedGT got my vote Link to comment Share on other sites More sharing options...
Blackmage Posted April 1, 2015 Report Share Posted April 1, 2015 wow pretty close race thus far! Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted April 1, 2015 Moderators Report Share Posted April 1, 2015 Went with my nom @Ferocious! Link to comment Share on other sites More sharing options...
95riosnake Posted April 1, 2015 Report Share Posted April 1, 2015 After much deliberation, @1SlammedGT got mine Link to comment Share on other sites More sharing options...
1SlammedGT Posted April 1, 2015 Report Share Posted April 1, 2015 lmao i just read the comments wow cool to see him getting his ass handed to him by open minded mustangers though @1SlammedGT got my voteThanks Tony. After much deliberation, @1SlammedGT got mineThanks Dan. Link to comment Share on other sites More sharing options...
Ferocious Posted April 2, 2015 Report Share Posted April 2, 2015 Still torn on who to vote for, I'm gonna force myself to vote before the end of the day lol. And LOL at the guy getting all upset about stanced/slammed mustangs on the post I put up on our IG page lol. Don't worry though, his bolt on sn with bullitts would give you all a run for your money, lol smh. yo fuck that fool basic ass bitch hating on the 3 piece wheels. tisk tisk Link to comment Share on other sites More sharing options...
95riosnake Posted April 2, 2015 Report Share Posted April 2, 2015 yo fuck that fool basic ass bitch hating on the 3 piece wheels. tisk tisk I think the mustang scene has grown a lot in the past couple years, more people seem to be open minded than they used to... but you're always going to run into a Cro-Magnon purist that thinks we're all ruining these cars. They're just cars lol, people need to calm down. Link to comment Share on other sites More sharing options...
410sn95 Posted April 2, 2015 Report Share Posted April 2, 2015 I think the mustang scene has grown a lot in the past couple years, more people seem to be open minded than they used to... but you're always going to run into a Cro-Magnon purist that thinks we're all ruining these cars. They're just cars lol, people need to calm down. I haz JDM forged two piece wheels. Got lots of hate from the general Mustang crowd at first just cause... Yet Chinese cast replicas were the bees knees. Link to comment Share on other sites More sharing options...
95riosnake Posted April 2, 2015 Report Share Posted April 2, 2015 I haz JDM forged two piece wheels. Got lots of hate from the general Mustang crowd at first just cause... Yet Chinese cast replicas were the bees knees. Honestly I remember the first time I saw a shot of your car, what drew me in was the wheels. They were a breath of fresh air... then I saw under the hood and hyperventilated a little but it's ok. Link to comment Share on other sites More sharing options...
410sn95 Posted April 2, 2015 Report Share Posted April 2, 2015 Honestly I remember the first time I saw a shot of your car, what drew me in was the wheels. They were a breath of fresh air... then I saw under the hood and hyperventilated a little but it's ok. Lol! Thanks. Honestly, some of you guys here on this site are really taking things to the next level in terms of fresh air. Me likey. Link to comment Share on other sites More sharing options...
Prokiller Posted April 3, 2015 Author Report Share Posted April 3, 2015 voting ends tomorrow! Link to comment Share on other sites More sharing options...
Steve-Oh Posted April 4, 2015 Report Share Posted April 4, 2015 Shit Link to comment Share on other sites More sharing options...
Prokiller Posted April 4, 2015 Author Report Share Posted April 4, 2015 Voting is closed. Link to comment Share on other sites More sharing options...
