iRoush Posted March 18, 2013 Report Posted March 18, 2013 (edited) I will be listing all the weights that came off my car just as a guide so you can all see how light you can make your car!My car's initial weight was about 3650lbs.Added Weight:MM 4-Point Cage w/ Harness Bar - +85lbsWicked Motorsports Rear Diffuser - +15lbsWeight Reduction Step 1:Iron 2v to Teksid 2v Swap - 115lbsSteel Flywheel to Aluminum Flywheel - 18.5lbsRoush Tool Kit - 15lbsSpare Tire Cover - 5lbsDriver Airbag Module - 4lbsAirbag Diagnostic Module - 13ozFR500 Wheel to MOMO Race wheel - 2lbsFront Coilovers (Both Sides) - 20lbsLeather Seats (Front) to Racing Seats - 56lbsRemoval of Leather Seats (Rear) - 50lbsPower Seat Tracks to Custom seat track (driver) and manual track passenger - 25lbsSunvisors - 2lbsRear Axle Dog Bone - 10lbsRear Seat Belts - 5lbsSpare tire = 25LbsJack and tire iron = 8LbsEGR and DPFE = 4LbsQuad Shocks w/brackets = 8LbsMach 460 Rear Deck - 17lbs 1.6ozMach 460 Rear Deck Cover - 2lbs 6.6ozMach 460 Front Speaker - 2lbs 8.6oz (x2)Mach 460 Tweeter - 11.6oz (x2)Mach 460 Tweeter Mount - 3.8oz (x2)Quarter Panel Trunk Carpet - 1lb 12oz (x2)Rear Trunk Panel Carpet - 1lb 8ozTrunk Latch Cover - 4.8ozMach 460 Amp - 2lbs 6.8oz (x2)Trunk Carpeting - 6lbs 5.2ozHead Unit - 2lbs 15.8ozMach 460 Front Amp - 1lb 7.8ozHVAC Panel - 13.8ozGlovebox - 3lbs 3.2ozPassenger Airbag Module - 8lbs 8.4ozBattery Tray - 12.8ozBattery - 38lbs 9.6oz (-14lbs) = 24lbs 9.6ozA/C Hose - 9.4ozUnder Dash Panel - 2lbs 4.4ozMach 460 dash harness - 3.6ozUndercarpet - 3lbs 14.8ozPassenger Side A-Pillar - 7.2ozWindshield wiper - 4.2ozTriple A-Pillar Pod - 15.8ozTrunk Weatherseal - 1lb 10.6ozSound Deadener - 5lbsInterior Panel foam - 4lbsPartial Removal of Firewall Blanket - 9lbsA/C Compressor - 13lbs 11.4ozA/C Condenser - 5lbs 10.2ozA/C Line - 5.4ozA/C Bottle/Line - 2lbs 14.8ozA/C Canister Bracket - 8.4ozA/C Canister - 2lbs 9.8ozCruise Control Module -2lbs 15.6ozWindshield Wash Reservoir - 2lbs 0.2ozHorn Assembly - 1lb 3.8ozTotal Removed: 517.7lbsTotal Added: 100lbsNet Weight Loss: 417.7lbsI will be adding more as I remember or as I take out more! Edited May 10, 2013 by iRoush
Det_Riot Posted March 18, 2013 Report Posted March 18, 2013 yah skinny that fat bitch up! these pigs need 500 yrds of runway and we only got 400! Time to put these ladies on a diet!
F8L GT Posted March 18, 2013 Report Posted March 18, 2013 I should've done this when i put mine on a diet but Frank did his shortly after
Blackmage Posted March 18, 2013 Report Posted March 18, 2013 just curious when you weighed your teksid block vs your iron, block, did you do it with heads and stuff or just the blocks themselves? When i weighed mine vs each other, they were both just block, internals, oil pans, bare heads. and the 2v came out 22 lbs heavier. i realize the heads are way bigger on the 4v's. but i didn't think bare block vs bare block they were 118 lbs different.
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 just curious when you weighed your teksid block vs your iron, block, did you do it with heads and stuff or just the blocks themselves? When i weighed mine vs each other, they were both just block, internals, oil pans, bare heads. and the 2v came out 22 lbs heavier. i realize the heads are way bigger on the 4v's. but i didn't think bare block vs bare block they were 118 lbs different.full dress vs. full dress. the internals that I used on the teksid are the lightest available. everything adds up!
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 As the car currently sits:I will be using www.florida50.com for their radio delete panels as well as a panel for the passenger airbag delete.
Blackmage Posted March 18, 2013 Report Posted March 18, 2013 full dress vs. full dress. the internals that I used on the teksid are the lightest available. everything adds up!ah ok! that makes more sense!
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 There's no way the trunk carpet is 7.5lbsHave you weighed your trunk carpet? I used my scale to weigh it. The insulation attached to the underside of the carpet is what adds all the weight.
Schiffy Posted March 18, 2013 Report Posted March 18, 2013 Have you weighed your trunk carpet? I used my scale to weigh it. The insulation attached to the underside of the carpet is what adds all the weight.Holy crap! lol
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 Holy crap! lolThe difference is huge. that insulation is what keeps the fuel pump noise and rear axle noise to a minimum. Taking that carpet out i hear every little noise from back there.
F8L GT Posted March 18, 2013 Report Posted March 18, 2013 Even all the crap sound deadening weighs a lot. Right not with stock seats, seat tracks, full interior minus back seat, full trunk interior and stock k member I'm sitting at 2850 race weight without driver
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 Yessir, next weekend I will be dry icing the interior and knocking out all the sound deadening on mine.
F8L GT Posted March 18, 2013 Report Posted March 18, 2013 Scrapper insert on a saws-all also works wonders
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 Scrapper insert on a saws-all also works wondersthat works, but I learned the quickest and less messy/gooey way of doing it is dry ice. I did it on my v6 mustang and I was done with the project in under an hour.
Schiffy Posted March 18, 2013 Report Posted March 18, 2013 that works, but I learned the quickest and less messy/gooey way of doing it is dry ice. I did it on my v6 mustang and I was done with the project in under an hour. That's badass! Wish I would have known about this when we did my buddies 93 hatch. Took us forever taking it out. We actually heated it up and scraped it. Talk about a mess!
Det_Riot Posted March 18, 2013 Report Posted March 18, 2013 Maybe stupid question: Where do you get dry ice from? :shrugs:
95riosnake Posted March 18, 2013 Report Posted March 18, 2013 Trunk Latch Cover. - 2.5lbsAre you saying this weighs 2.5 lbs? :suspicious:
Blackmage Posted March 18, 2013 Report Posted March 18, 2013 Battery Tray - 3lbsthis isn't 3 lbs either..
Moderators Psychorugby Posted March 18, 2013 Moderators Report Posted March 18, 2013 Under 3300lbs already! Wow! (How much for your FR500 wheel haha?)
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 (edited) Maybe stupid question: Where do you get dry ice from? :shrugs:There are places locally that are dry ice distributors, it's not a dumb question because I had no idea either but dry ice stores are more common then I thought at least out here lol.Are you saying this weighs 2.5 lbs? :suspicious:with all hardware attached yes.this isn't 3 lbs either..once again with all hardware attached yes it is.my weight watchers scale doesn't lie sirs!! haha Edited March 18, 2013 by iRoush
95riosnake Posted March 18, 2013 Report Posted March 18, 2013 (edited) The only hardware attached to that trunk latch cover is 4 plastic push pins, your cover must be made of metal because mine weighs nowhere near 2.5lbs. Not trying to rake you over the coals about it but if this thread is about weight savings, the weights need to be accurate. Edited March 18, 2013 by 95riosnake
F8L GT Posted March 18, 2013 Report Posted March 18, 2013 dont weight watchers scales measure in ounces?
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 The only hardware attached to that trunk latch cover is 4 plastic push pins, your cover must be made of metal because mine weighs nowhere near 2.5lbs. Not trying to rake you over the coals about it but if this thread is about weight savings, the weights need to be accurate.if I have to I'll pick up another scale to verify, I'm going by what it reads on the scale if its wrong then I'll change it.
Jeremy95GT Posted March 18, 2013 Report Posted March 18, 2013 Gas cap... 13.8 lbs... I think this is amazing.... Half the shit your taking out however I can not live without... But your gonna have a supa light car when ur done....Jeremy
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 Gas cap... 13.8 lbs... I think this is amazing.... Half the shit your taking out however I can not live without... But your gonna have a supa light car when ur done....Jeremyhaha thanks bud. as far as the weight stuff goes I'd rather be raked over the coals if I have weights wrong that way I can fix it. I'll be picking up another scale this weekend, Preferrably a dial scale as digital ones aren't always accurate
Jeremy95GT Posted March 18, 2013 Report Posted March 18, 2013 I'm just pickin on ya man... Your doin work over there.. that's all that mattersJeremy
95riosnake Posted March 18, 2013 Report Posted March 18, 2013 haha thanks bud. as far as the weight stuff goes I'd rather be raked over the coals if I have weights wrong that way I can fix it. I'll be picking up another scale this weekend, Preferrably a dial scale as digital ones aren't always accurateI hope you don't think I'm being a dick, it just seemed off to me.
iRoush Posted March 18, 2013 Author Report Posted March 18, 2013 I hope you don't think I'm being a dick, it just seemed off to me.you're the biggest dick on the whole Internet!!!!!!haha JK man, I'd rather see someone question the weight and provide input than having nobody post at all. Feedback is always necessary and appreciated.
WildWillyWalker Posted March 20, 2013 Report Posted March 20, 2013 just curious when you weighed your teksid block vs your iron, block, did you do it with heads and stuff or just the blocks themselves? When i weighed mine vs each other, they were both just block, internals, oil pans, bare heads. and the 2v came out 22 lbs heavier. i realize the heads are way bigger on the 4v's. but i didn't think bare block vs bare block they were 118 lbs different.Internals will make a big difference. However, the Cobra forged crank is heavier than a non-forged crank. I know the Teksid block is around 80 lbs. I forget what a bare iron block weighs.Edit: Durr, forgot to say awesome post iRoush! I'm enjoying looking over it.
iRoush Posted March 20, 2013 Author Report Posted March 20, 2013 Internals will make a big difference. However, the Cobra forged crank is heavier than a non-forged crank. I know the Teksid block is around 80 lbs. I forget what a bare iron block weighs.Edit: Durr, forgot to say awesome post iRoush! I'm enjoying looking over it.I'm using a cast crank not forged! believe me I went through every detail to lighten this car up!
WildWillyWalker Posted March 20, 2013 Report Posted March 20, 2013 I figured you did. I wasn't implying you used a forged crank. That's quite an advantage for you since you aren't boosting anyway.
iRoush Posted March 20, 2013 Author Report Posted March 20, 2013 I figured you did. I wasn't implying you used a forged crank. That's quite an advantage for you since you aren't boosting anyway.forged cranks are really worthless until about 600hp anyway. the rods are the weak link, but regardless, yessir huge advantage in rotating mass as well as actual weight
iRoush Posted March 23, 2013 Author Report Posted March 23, 2013 Small Update. Thanks to my local USPS office, they donated a free scale to my cause. (the one's that way the boxes for shipment). These are spot on because they have to be so it should provide. a little more accurate numberrs.]
Jeremy95GT Posted March 23, 2013 Report Posted March 23, 2013 That's cool as hell, you just went in there and asked?Jeremy
iRoush Posted March 23, 2013 Author Report Posted March 23, 2013 That's cool as hell, you just went in there and asked?Jeremyasked if they had any spare ones that they weren't using and they just gave me one lol. i was willing to pay some cash for it but it worked out even better.
Jeremy95GT Posted March 23, 2013 Report Posted March 23, 2013 Man that's really cool, not many people out there these days willing to give something away without asking for your first born... Now you should have some solid numbers to provide.... Gotta save weight with those heavy gas caps... Jeremy
