Prokiller Posted January 8, 2014 Report Share Posted January 8, 2014 This month we are going with our most common enthusiast mustang, the ever tried and true Grand Touring edition. We actually had a tie with the nominations this month for the last spot and as such, we're going to have 5 contestants. I tinkered with the idea of dropping out this month since I'm one of the nominees, but figured if everyone had nominated me then i should at least include myself. Also, there is no prize this month so i feel better about including myself. Getting back to the point at hand here. It all started back in 1965 when the mustang was still wet behind the ears. it was a bold year when such songs as "You've lost that lovin' feeling" by the Righteous Brothers topped the charts and the first combat troops were sent to Vietnam. The US and USSR were testing nukes on land in the cold war arms race. It was the best of times...it was the worst of times...Obviously though the pinnacle achievement of that year was the ever so loved Mustang GT. We're going to pay homage to that classic period in history with this month's Ride of the Month! MusturdPerformance:Forged 306Wire tucked engine bayPorted gt40 headsProfessional products typhoon intake1/2" phenolic spacerBbk 70 mm tbMsd cap and rotorFrpp plug wiresBbk long tubesBbk off road x pipeFlowmaster cat backGforce t5 transAct clutchFrpp aluminum drive shaftFrpp 3.73 gearsCobra brakes front and rearCross drilled and slotted rotorsFrpp 31 spline t lockFrpp 31 spline axlesNos 125 wet shotF303 camUpr tubular k memberCoiloversUpr pro series rear suspensionUpr caster camber plates Interior:Acura rsx seatsMM 6pt cage10lb nos bottleHurst sidewinder shift knobAuto meter sport comp monster tachBattery relocationExterior:Oem cobra front bumper with fogsOem cobra hoodOem cobra headlightsOem cobra rear bumper96-98 tail lightsCustom shorty antennaBogart d10 wheels28x12.50-15165/70-15 frontsShaved passenger keyholeShaved third brake light .Computstar pager system with remote window module Blackmage-Performance93 Mark VIII long block98 Cobra Intake97 Cobra intake CamsIMRC DeleteEGR Delete03 Cobra manifoldsO/R H-pipe into stock mufflersCoil pack's relocatedK&N Filter00 Cobra R calipers on order..Spec Stage 2 clutch99 Cobra T45Steeda Tri-Ax4.10 gearsFRPP Carbon disc trac-lok rebuildAerostar Aluminum D/S -SuspensionCut Ford C-SpringsSteeda front & rear sway barsKYB AGX strutsSR Upper & Lower control armsFRPP Strut Tower BraceMaximum Motorsports FLSFC -Exterior96 Cobra HoodDark tinted cobra headlights5% tinted windows99 mustang spoilertinted taillightsFront pony deleteViolet pearl in new black paintSequential and Chase taillights by Meter4itHID's 6000k -InteriorCar is 248a optioned, meaning its basically a GTS: -No power windows, no power seats, no rear defrost, no fog lights, no spoiler, V6 seats, basic radio, no ABS, no trunk release buttonFR500 steering wheelFRPP shift knobBullitt Style pedal coversCobra gauge clusterGray GT floor mats and Charcoal carpet -Wheels/Tires18x9 and 18x10 GodSpeed wheels275/35/18 Michelin Pilot Sport 2285/35/18 Michelin Pilot Sport 3 SolarPerformance:K&N Drop in FilterRoush 75mm TBMAC Off-Road H-pipeCustom Cat-BackBAMA Tune (Until I get real performance parts to really tune)SSBC Slotted RotorsHAWK Performance Brake Pads Suspension:MM CC PlatesMM FLSFCBilstein HD Struts/ShocksMM Bumpsteer KitH&R SS Springs Exterior:Rear Spoiler DeleteTerminator side mirrorsMach 1 Grill Delete (No Pony)Mach 1 Chin Spoiler Interior:FR500 Steering WheelMGW Short Throw ShifterMGW Rally style ball shifter with running pony Wheels Tires:SVE Drift Wheels (18x9 and 18x10)Nitto INVO Tires (265/35/18 & 295/35/18)Roush Wheels for AutoX thanks to iRoush Whiplash473---Performance---TFS Track Heat upper/lower manifoldsTFS cam (.498/.510)TFS Black valve coversTFS 170 heads with 61cc chambersTFS hardened pushrodsTFS 1.6 rockersTFS hydraulic liftersProM 80mm MAF and filterEdelbrock 65MM throttle body (upgrade soon)30# Ford injectorsDSS 331 4" stroker kit (10.48:1 compression)Romac balancerMoroso 7qt oil panHigh volume oil pump(forgot brand)Clevite main/rod bearingsCenterforce 500# clutchStock spec rebuilt T53.73:1 rearBBK chrome long tubesCustom welded one piece X with Flowmaster Super 44s (dumped) ---Suspension---Dropped 3" front and about 2.75" rearMaxpeed springsTokico fox struts/shocksMM bumpsteer kitMM solid rack bushingsProthane sway bar bushings ---Exterior---Respray and all other body work done by meDebadgedCobra front coverCervini Ram Air hood (was waiting on hardware so it's not on in the pic above)Cervini Stalker wing (in the process of being sprayed, not in pic above) ---Interior---Pro5.0 short throwwhite gauge facesAEM AFR gauge (pillar) (pillar gauges not in pic above)AEM water temp gauge (pillar)AEM oil pressure gauge (pillar) ---Wheels/Tires---03 Cobra wheels (resprayed by me)9" front and 10.5" rearNitto 315 DR's (rear) and Riken 275 Raptors (front) ProkillerEngine:-D.S.S. Super Pro Bullet 331 Stroker block with Series 20 upgrade-Forged D.S.S. Pro-Lite Pistons-Forged D.S.S. H-beam rods-Cast Stroker Crank-Felpro MLS head gaskets-D.S.S. Windage Tray-D.S.S. Main Support Girdle-D.S.S. 7qt. Oil pan with FMS High Volume Oil Pump-Vortech S-trim SQ-V2 (2.95" pulley)-AFM Power Pipe-AFR Competition 185 58cc heads-Trick Flow Stud Mount 1.72 Roller Rockers-Moroso fabricated aluminum valve covers w/ JIC fittings for breather-Moroso breather tank w/ JIC fittings/lines-AFM B-21 Cam (218/226 .542/.542 w/1.7 rocker 272/280 112 108)-FRPP lifters-Edelbrock Performer RPM intake-1" phenolic intake spacer-Stack Racing Polished 70mm Throttle Body-Pro-M 80MM mass air w/ attached filter-42lb FRPP Injectors-Aeromotive Fuel Pressure Regulator-PA Performance 130-amp Alternator-BBK 1 5/8" ceramic coated long tube headers w/ Stage 8 locking header bolts-Dr. Gas 2 1/2" x-pipe-DynoMax race bullet mufflers-Borla duul slant cut round intercooled exhaust tips for side exhaust-255lph intank fuel pump-T-Rex inline fuel pump-MSD Pro-Billet Distributor-MSD coil w/ Ford Motorsports 8mm wires-MSD 6A Ignition system mounted in glove box-Fluidyne Aluminum Radiator-Manual Fan switch-AFM PMS w/ boost controller-Billet Smog Pump Delete (99.5" belt)-Most wires hidden-EGR Deleted-A/C DeletedDrivetrain:-Tremec 3550 upgraded with 26-spline input shaft and larger output shaft-Mcleod clutch-Fidanza steel flywheel-Maximum Motorsports Clutch Cable-Steeda Double Clutch Quadrant-AM Firewall Adjuster-Lakewood poly trans mount-Stifflers trans crossmember-Pro 5.0 shifter-Ford Motorsports Aluminum Driveshaft-Steeda driveshaft spacer-FRPP Driveshaft Safety Loop-Ford Motorsports 3.73 gears-Moser 28-spline axles-Trick Flow Rear Stud GirdleSuspension:-Ford Racing Lowering Springs (I think C's)-KYB Rear Shocks-Vintage Venom GT500 brake conversion kit-4-piston Brembo front calipers-14" Brembo slotted front rotors-Goodyear stainless lines-Ford Racing cobra rear calipers-slotted Brembo rear rotors-J&M stainless lines-Steeda Aluminum Lower Control Arms-Steeda Adjustable Upper Control Arms-Maximum Motorsports 4-bolt Caster/Camber Plates-BBK Strut Tower Brace-Kenny Brown full length welded in subframe connectors-2003 Cobra Rack (SPR-ZM)Exterior:-Fresh paint job :: Black with blue pearl, ghost blue pearl dual stripes-Cobra R Hood w/ Hood Pins-ABC Exclusives GTR front bumper smoothed on the sides-Roush Side exhaust side skirts-Saleen T1 race spoiler-Export horizontal tail lights w/ amber turn signals-Black Bullit fuel door-Ultra Clear Headlights-Ultra Clear Side Markers-Clear Rear Reflectors-19 x 8.5" TSW Gunmetal machined Nurburgring wheels-255/40-19 Mickey Thompson Street Comp tires-20 x 10" TSW Gunmetal machined Nurburgring wheels-305/35-20 Nitto NT555R drag radials-Window Tint-Painted Red Calipers w/ Pony Stickers-Silver Bumper Inserts-Painted Mirrors-Rolled fendersInterior:-Painted Interior pieces-White Face Gauges w/ LED light mod and red needles-Sinus Industries Gauge Ring Bezel-Amustangrocksleather center console cover-White HVAC panel w/ LED light mod-LED Reverse lights-LED dome lights-LED license plate lights-Autometer 2 gauge pillar pod-Autometer 2 gauge cluster pod-Autometer 2 gauge clock pod converted for wideband-Autometer C2 Boost, Water Temperature, Oil Pressure, Fuel Pressure gauges-Autometer C2 Tachometer w/ UPR Tach Bracket-AFM Uego 2000 wideband sensor (partially installed. Still have to hook up to Tach/PMS)-Bullet Shifter Knob-Billet Headlight Knob-Billet Window Switches-Billet Clothes Hangers-Billet HVAC Contols-Billet Cigeratte Lighter-Billet E-Brake Handle-Billet Door Lock Pins-Billet Cruise Control Buttons-AFM Billet Ash Tray Switch-Neon Blue Lights under the dash-JVC headunit-Pioneer Tweeters-Viper Alarm I realized that I have no pictures of my interior other than from 5 years ago....wow...so i'm going leave this here instead. Let the Voting Begin!!!! Link to comment Share on other sites More sharing options...
Steve@CJPP Posted January 8, 2014 Report Share Posted January 8, 2014 so much win, I must study this a little more before casting my vote. Link to comment Share on other sites More sharing options...
Solar Posted January 8, 2014 Report Share Posted January 8, 2014 hmmmmmmmmmmmmm Link to comment Share on other sites More sharing options...
Orange 94 Posted January 8, 2014 Report Share Posted January 8, 2014 Great list! Whiplash needs to "finish" the car and share a top notch photoshoot asap! Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted January 8, 2014 Moderators Report Share Posted January 8, 2014 Two spoke to me, one spoke louder. Link to comment Share on other sites More sharing options...
Musturd Posted January 8, 2014 Report Share Posted January 8, 2014 Sexy line up of rides Link to comment Share on other sites More sharing options...
Steve-Oh Posted January 8, 2014 Report Share Posted January 8, 2014 Damnit, I dunno. Rock paper scissors...? Sent from Space Link to comment Share on other sites More sharing options...
Blackmage Posted January 8, 2014 Report Share Posted January 8, 2014 I feel like an outcast with a 4v motor... haha Link to comment Share on other sites More sharing options...
Det_Riot Posted January 9, 2014 Report Share Posted January 9, 2014 jjsdajalsdglk;asjglknabonalsb ARGHHHH: this shit is HARDDDDDDDD Link to comment Share on other sites More sharing options...
Whiplash473 Posted January 9, 2014 Report Share Posted January 9, 2014 Wish my damn car was done, spring-time cannot arrive fast enough. EDIT: Great cars this month, I like all of them in their own ways. Link to comment Share on other sites More sharing options...
Musturd Posted January 9, 2014 Report Share Posted January 9, 2014 Wish my damn car was done, spring-time cannot arrive fast enough. EDIT: Great cars this month, I like all of them in their own ways.Same can't wait for spring time. At the same time I can wait a little because quite a bit of stuff is getting done right now lol Link to comment Share on other sites More sharing options...
Whiplash473 Posted January 9, 2014 Report Share Posted January 9, 2014 Same can't wait for spring time. At the same time I can wait a little because quite a bit of stuff is getting done right now lol Yeah I'm waiting to get mine to the tuner and spray my wing. Without being able to ride sled this winter I'm pretty much counting the seconds till spring comes. Link to comment Share on other sites More sharing options...
Musturd Posted January 9, 2014 Report Share Posted January 9, 2014 Yeah I'm waiting to get mine to the tuner and spray my wing. Without being able to ride sled this winter I'm pretty much counting the seconds till spring comes.Why no sledding ? Yea track doses to open till may 2nd 2 weeks later then normal and the shit talking and call outs are already starting Link to comment Share on other sites More sharing options...
Whiplash473 Posted January 9, 2014 Report Share Posted January 9, 2014 Well money has been stupid tight for the last month so it's really just not worth pinching the pennies to go out. Link to comment Share on other sites More sharing options...
Musturd Posted January 9, 2014 Report Share Posted January 9, 2014 Yea all good I hear that , finally getting shit back together my snow removal money is finally coming in so car mods can commence Link to comment Share on other sites More sharing options...
Sleeperstang1994 Posted January 9, 2014 Report Share Posted January 9, 2014 crank windows WHAT! seriously though. nice looking cars Link to comment Share on other sites More sharing options...
Whiplash473 Posted January 9, 2014 Report Share Posted January 9, 2014 GTS got dat weight reduction. Sent from bored/stroked iPhone 4S Link to comment Share on other sites More sharing options...
95riosnake Posted January 9, 2014 Report Share Posted January 9, 2014 I can't decide on this, ugh! Link to comment Share on other sites More sharing options...
Steve-Oh Posted January 10, 2014 Report Share Posted January 10, 2014 I just closed my eyes and clicked. Link to comment Share on other sites More sharing options...
iRoush Posted January 10, 2014 Report Share Posted January 10, 2014 my vote went to solar but it was a tough choice. All cars are worthy and deserving! Link to comment Share on other sites More sharing options...
Prokiller Posted January 10, 2014 Author Report Share Posted January 10, 2014 i'm going to let this go the weekend. going to close it down on Monday! Link to comment Share on other sites More sharing options...
MaximumRisk Posted January 10, 2014 Report Share Posted January 10, 2014 Voted! Good luck to everyone Link to comment Share on other sites More sharing options...
Tony Posted January 11, 2014 Report Share Posted January 11, 2014 i voted for the guy that kills the pro's Link to comment Share on other sites More sharing options...
95riosnake Posted January 11, 2014 Report Share Posted January 11, 2014 It was a tough choice this month, but I finally pulled the trigger on one Link to comment Share on other sites More sharing options...
Prokiller Posted January 13, 2014 Author Report Share Posted January 13, 2014 voting closed. Link to comment Share on other sites More sharing options...
