Prokiller
November ROTM Voting Thread - N/A Powered
Who is your ROTM Winner?
32 members have voted
  1. 1. Who is your ROTM Winner?
    • DET_RIOT
      13
    • NVRL8TE
      5
    • STEVE-OH
      11
    • WHIPLASH473
      3
Come one come all to ye ole November Ride of the Month voting thread! I'll give you all a second to find your assigned seats at the SN95Source thanksgiving table. Settle down, settle down everyone. Tony! take your seat at the kids table. Now that everyone is seated, we can begin.
Thank you great being in the ether for providing us with fire, for without which we could not have internal combustion
Thank you for the wonder of urethane for without we would still be using wood body panels
Thank you for killing the dinosaurs, for their sacrifice has given us oil
Thank you for the Hevea brasiliensis tree, allowing us to create such miracles as drag radials
We give thanks to the car gods for bringing these components together to create our beloved Mustang.
AMEN!
Now without further pomp and circumstance, let's vote!!
DET_RIOT
Exterior
-Boss Inc 2000r Hood
-Depo Projector Headlights
-Black Cornerlights
-OEM Ford Cobra Bumper
-30%/20%tint
-Fiberglass s281 Wing
-SVO Side Skirts
-Export Tail Lights
-Paint Matched Mirrors
-Debadged
Interior
-Corbeau TRS Seats
-Autometer Wideband
-Nordskog Digital Gauge Cluster
-MMR Rear Seat Delete
-03 Cobra Center Console
-Powdercoated Mach 1 Shift Knob
-Panasonic Headset
Performance
-170cc twisted wedge Heads with 7-angle valve job
-Comp Cams 985-16 Valve Springs
-FRRP 1.6rr's
-Trick flow pushrods
-Edelbrock RPM II Intake Manifold Powdercoated to Match
-75mm PP throttle body
-AFM N-412 Camshaft
-90mm LMAF
-Custom 4" Cold Air Intake
-MSD Pro Billet distributor
-Mickey Thompson Valve Covers
-Ford Racing Harmonic Balancer
-MSD Streetfire Coil
-BBK Long tube Headers
-BBK O/R X-pipe
-Borla Tips
-Borla Stingers
Suspension
-HPM Megabite Jr Upper & Lower Control arms
-Polyurethene Bushings
-TeamZ Drag Springs (Rear)
-Tokico Shocks
-Bilstein Struts
-Maximum Motorsports Front coilover Kit
-Kenny Brown Camber-Caster Plates
-03 Mach One Calipers
-Front 13" Brembo Rotors
-Raybestos Pads
-11.5" Cobra Rear Brake Conversion
-Raybestos Rear Brake Pads
-Maximum Motorsports 6pt Cage
-Cobra Steering Rack
-Cobra Steering Shaft
Drivetrain
-Tremec 3550 Rebuilt by Hanlon Motorsports to TKO 600 Specs
-26spline input, 31 spline output
-Mcleod Blowthrough Bellhousing
-Steeda Tri-Ax Shifter
-Ford Racing Aluminum Driveshaft
-Spec Stage 3 Clutch
-Ford Racing 4.30 Gears
Wheels/Tires
-18x8.5 18x10 BBS RK Plasma
-Black Chrome PVD Coated
-245/45r18 Aurora All Seasons
-305/35r18 Mickey Thompson ET Street Radials
NVRL8TE:
-Performance
T56 swap
4.56 gears, rebuilt rear
Custom off road x pipe, Borla stingers, stock manifolds.
Stock engine, airbox to manifolds, intake to TB.
-Suspension
some Team Z suspension, Strange shocks
-Exterior
stock exterior
-Interior
Corbeau A4 seats, rear seat delete
-Wheels/Tires
billet specialties 15x10/15x3.5 275/50 ET streets, 165/80 fronts
best et of 12.39 @ 108
dynos 300 RWHP
weighs 3200 flat without me in it
STEVE-OH:
Performance:
  • Ford Racing 427W crate motor
  • 4.125 bore / 4.00 stroke
  • SCAT forged crank & I-beam rods
  • Forged Mahle pistons 10.5:1
  • Hydra roller cam .576/.600 ; 242/248
  • FRPP Aluminum “Z” heads 2.02 intake / 1.60 exhaust
  • Ford EFI distributor, MSD cap/rotor
  • Edlebrock Victor upper/lower
  • BBK 75MM throttle body
  • C&L intake tube
  • FRPP 90MM L-MAF
  • MSD 6A box
  • Aeromotive rails, braided lines from firewall, FRPP 47lb'ers and a 255 Walbro
  • BBK shorties, rigged up off-road “h”, Flowmaster exhaust
  • FRPP 4.10 gears
  • ...and a basically stock T-5 Transmission!
  • Tuning by Keith Varin (The Mk2)
Suspension:
  • Maximum Motorsports K-member, A-arms, rear lower adj. control arms, front coilover kit & CC plates
  • Blistein front struts with Hypercoils & Bilstein rear shocks with H&R Supersports
  • Steeda full length subframe connectors
  • Steeda bump steer
Exterior:
  • H.O. Fibertrends 3.5” Cobra R hood
  • Export rear tailights
  • DEPO projector headlights (matching sidemarkers) de-chromed and painted black
  • “Poxenham” front tow hook
Interior:
  • Pioneer AVIC double din swap
  • Autometer Lunar gauges
  • Push button start (inactive)
  • Crappy factory seats
  • SVT rear seat delete / sub & amp mount (made by yours truly)
Wheels / Tires:
  • GT500 replicas: 18x9 front /18x10 rear
  • Pirelli P-Zero Rosso's: 265/35 front ; 315/30 rear
Whiplash473:
Performance:
10.5:1 compression
ProM 80mm MAF + filter
4" Anderson Power Pipe
75mm BBK throttle body
TFS track heat upper/lower intakes
TFS 170cc heads + 1.6 full roller rockers
TFS hydraulic lifters
TFS cam: .499/.510
DSS 331 4" forged stroker kit + matched flywheel
Romac balancer
BBK long tubes
Centerforce dual friction clutch
rebuilt T5 with FRPP kit
7qt Moroso oil pan
ARP oil shaft with high volume pump
3.73:1 gears
Energy Suspension motor/trans mounts
Suspension:
Front -
MM c/c plates
Tokico fox struts
MM bolt-through bumpsteer kit
MM solid rack bushings
Maxspeed yellow springs (cut a couple coils)
Rear -
Maxspeed yellow springs (cut)
Tokico fox struts
MM lower and upper control arms coming soon enough
Exterior:
cobra front cover
Cervini ram air hood
Cervini stalker wing
debadged fenders and trunk lid
shaved antenna
shaved engine bay (custom, not the panels you buy)
no orange peel
windows getting tinted in the spring
dakota swapped fogs
'96 tails
Interior:
Pro 5.0 shifter
AEM digital water temp, analog oil pressure, and wideband in triple pillar pod (not in pic of interior above)
white gauge faces
Wheels/tires:
Front:
03 cobra x9's with Riken Raptor 275/40/17
Rear:
03 cobra x10.5's with Nitto 555R 315/35/17
- - - Updated - - -
also sorry for the delay, had some anniversary stuff to do today. Voting will go until Monday!
Ok so what I am going to do, is take the first two cars, flip a coin the winner moves on the the finals, do the same for the last two then the winner of the two filps will then be flipped for my pick because there is no possible way I can make this decision on my own lol.
  • Moderators
Essentially what I did except 1 and 4, 2 and 3. Bryan won!
I love all the cars in this thread, all top notch examples of SN's.
In the end I tipped my hat to Bryan, gotta admire the dedication you have and it could never be considered even close to a cookie cutter mustang :thumb:
If you haven't voted, please do so. Closing this down in a couple hours
3 days lol, that's a short voting period
I still think it's ridiculous that we have 464 members on this site, 165 of which are active members according to the home page, yet we only have 19 votes in here...
Come on people, cast your votes.
Edited by 95riosnake
Guest
