Steve-Oh Posted June 18, 2015 Report Share Posted June 18, 2015 Couldn't wait that long, watched it on my phone with headphones. Jizz in my pants. Link to comment Share on other sites More sharing options...
SublimeRT Posted June 18, 2015 Report Share Posted June 18, 2015 Way to go man! Sounds real nasty! I sometimes forget these cars can make good noises and move under their own power. Link to comment Share on other sites More sharing options...
GTTRacing91PGT Posted June 19, 2015 Report Share Posted June 19, 2015 Congrats on the start up! Been following this quietly. Always exciting when she first fires! Great work Link to comment Share on other sites More sharing options...
Tony Posted June 19, 2015 Report Share Posted June 19, 2015 so this will be down at mustang week then right? Link to comment Share on other sites More sharing options...
Det_Riot Posted June 20, 2015 Author Report Share Posted June 20, 2015 Yessire new motor start: https://youtu.be/HPdl5t5BR3A Link to comment Share on other sites More sharing options...
Tony Posted June 20, 2015 Report Share Posted June 20, 2015 that video makes it look good without the side skirts lol. Link to comment Share on other sites More sharing options...
Musturd Posted June 22, 2015 Report Share Posted June 22, 2015 Right on dude haven't checked out your build in quite sometime nice to see you got it running with the new combo finally got mine going again today Link to comment Share on other sites More sharing options...
Det_Riot Posted June 22, 2015 Author Report Share Posted June 22, 2015 thanks @Musturd! its all set to go to the dyno tomorrow :crossesfingers: aside from this stupid charging issue I'm now having. Link to comment Share on other sites More sharing options...
Det_Riot Posted June 22, 2015 Author Report Share Posted June 22, 2015 Bryan any chance that you have a ground wire that is bad?!? Just seems odd that it charged fine before motor swap and now you have an issue.Would make me think it's an issue under the hood and possibly a ground wire that is either shorted or something.This message courtesy of crapatalk! Anything not related to the charging system is plausible at this point. I know it's going to end up being something dumb because it just doesn't make sense. The car starts up instantaneously so that's the only reason why I'm hesitant to think it isn't a ground but at this point your guess is as good as mine. Link to comment Share on other sites More sharing options...
Musturd Posted June 22, 2015 Report Share Posted June 22, 2015 Right on man . Yea I still need to get a alternator belt it's the only accessory on the car lmao . Can't wait to see what you make for numbers . Link to comment Share on other sites More sharing options...
Det_Riot Posted June 23, 2015 Author Report Share Posted June 23, 2015 https://www.youtube.com/embed/bTZRha6ccQc Link to comment Share on other sites More sharing options...
Musturd Posted June 23, 2015 Report Share Posted June 23, 2015 Nice sounds good what kinda numbers you make ? Happy with them ? Link to comment Share on other sites More sharing options...
Det_Riot Posted June 23, 2015 Author Report Share Posted June 23, 2015 Nice sounds good what kinda numbers you make ? Happy with them ?Thanks man! 351/366. Bit low, but the motor isn't really broken in yet and having a couple issues that I think are holding back power. I think there's Still more timing in it. He didn't wanna push it because open headers were throwing off AFR and timing isn't totally trustworthy. The car wasn't producing spark with the spout unplugged so gotta chase wiring issues. It looked like it was holding steady around 30-35 at 3k but he didn't want to push it without solid confirmation of everything functioning right.Though, he said I shouldn't have to do anything once I get it all straightened out. AFR was solid at 12.4:1 at WOT so unless it starts doing something funny after I fix the ignition wiring, he said I don't have to bring it back to him though I probably will to get final numbers and have it be totally worked out. Nice sounds good what kinda numbers you make ? Happy with them ?Here's dyno chartHere's the circuit I think I have the issue in. Since the spout completes the circuit for PCM controlled timing, I'm thinking there's an issue somewhere between the ignition coil and the PCM so when it's pulled, there's a break in wiring or something causing it to not feed spark. Link to comment Share on other sites More sharing options...
Prokiller Posted June 23, 2015 Report Share Posted June 23, 2015 i don't think they are are bad numbers at all though Bryan. is the charging still working? Link to comment Share on other sites More sharing options...
Zach Posted June 23, 2015 Report Share Posted June 23, 2015 I agree those are some good numbers n/a , hopefully you will get the timing issue fixed. Then get the timing were u want it.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Rolocut Posted June 23, 2015 Report Share Posted June 23, 2015 I would totally throw an exhaust on this pig Link to comment Share on other sites More sharing options...
Det_Riot Posted June 23, 2015 Author Report Share Posted June 23, 2015 i don't think they are are bad numbers at all though Bryan. is the charging still working?As of now lol I wonder if this timing fault was grounding out before and causing the charging system to go haywire and when I threw it all back together, it moved whatever damaged wire enough that its functioning as it should.I agree those are some good numbers n/a , hopefully you will get the timing issue fixed. Then get the timing were u want it.Sent from my iPhone using TapatalkThat's what I'm hoping for!I would totally throw an exhaust on this pigThat's the plan, just didn't have time to get it done Link to comment Share on other sites More sharing options...
Tabres Posted June 23, 2015 Report Share Posted June 23, 2015 I know you could never leave it like that, but it sounds so good with the open exhaust... Link to comment Share on other sites More sharing options...
Det_Riot Posted June 23, 2015 Author Report Share Posted June 23, 2015 I know you could never leave it like that, but it sounds so good with the open exhaust...Hahahah don't remind me. If it was pumping like 600+ na, I'd absolutely just rock some dumb little header mufflers and call it day ! Link to comment Share on other sites More sharing options...
Det_Riot Posted June 24, 2015 Author Report Share Posted June 24, 2015 Just some more fresh teal sex! Link to comment Share on other sites More sharing options...
Zach Posted June 24, 2015 Report Share Posted June 24, 2015 Damn that's a tough oneSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RedTwilight Posted June 24, 2015 Report Share Posted June 24, 2015 I know you could never leave it like that, but it sounds so good with the open exhaust... Hahahah don't remind me. If it was pumping like 600+ na, I'd absolutely just rock some dumb little header mufflers and call it day ! Electric exhaust cutouts FTW! :headbang: Link to comment Share on other sites More sharing options...
Steve-Oh Posted June 24, 2015 Report Share Posted June 24, 2015 Damn that's a tough oneSent from my iPhone using TapatalkWith ya, couldn't guess where that is either. Bryan's photo-graphy skillz are second to none [emoji6] Sent from Space Link to comment Share on other sites More sharing options...
95riosnake Posted June 25, 2015 Report Share Posted June 25, 2015 Ooh ooh I know what the new mystery part is Link to comment Share on other sites More sharing options...
Yeahloh95 Posted June 25, 2015 Report Share Posted June 25, 2015 i think i do too Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted June 25, 2015 Moderators Report Share Posted June 25, 2015 Export mirrors? Link to comment Share on other sites More sharing options...
Det_Riot Posted June 25, 2015 Author Report Share Posted June 25, 2015 I suppose if you checked off things it obviously wasn't, there wasn't a whole lot left lol Link to comment Share on other sites More sharing options...
Moderators Psychorugby Posted June 25, 2015 Moderators Report Share Posted June 25, 2015 Bastard. Damn those look good. Now I kinda want to do all my black trim in gloss black rather than the trim black. Link to comment Share on other sites More sharing options...
RedTwilight Posted June 25, 2015 Report Share Posted June 25, 2015 I'll second that BASTARD!!! I wish I could find a pair for sell. But first I'll have to get the money to afford them. Link to comment Share on other sites More sharing options...
Lanter Posted June 25, 2015 Report Share Posted June 25, 2015 Damn export tails and mirrors...... some people have it all! Link to comment Share on other sites More sharing options...
Zach Posted June 25, 2015 Report Share Posted June 25, 2015 Fackkk I found some mirrors and tails the other day but didn't have the $$$ looks good man.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Det_Riot Posted June 27, 2015 Author Report Share Posted June 27, 2015 Side exhaust fab pics courtesy of my buddy putting it together for me. Link to comment Share on other sites More sharing options...
Det_Riot Posted June 27, 2015 Author Report Share Posted June 27, 2015 Is that how your tips will be aimed or are they not finished!?!?This message courtesy of crapatalk!Haven't quite decided. I'm leaning towards having him keep them like this, and if the look doesn't grow on me, then I'll chop them down even like the regular borla tips are Link to comment Share on other sites More sharing options...
RedTwilight Posted June 28, 2015 Report Share Posted June 28, 2015 I like the look but maybe a hair shorter. If they were cut parallel to the skirt but still out an inch Id think that would be sexy!!!This message courtesy of crapatalk!And then mirror polished! Link to comment Share on other sites More sharing options...
Det_Riot Posted June 28, 2015 Author Report Share Posted June 28, 2015 Yeah it's all stainless. I need to see it all together with the car on the ground and such before I make the final decision about what I'm going to do with it Link to comment Share on other sites More sharing options...
Yeahloh95 Posted June 28, 2015 Report Share Posted June 28, 2015 how does it sound ? Link to comment Share on other sites More sharing options...
Det_Riot Posted June 28, 2015 Author Report Share Posted June 28, 2015 how does it sound ?Lol if I had it back you'd have videos already Link to comment Share on other sites More sharing options...
Det_Riot Posted June 30, 2015 Author Report Share Posted June 30, 2015 Nothing to see here, just 1240mm of rubber [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] Link to comment Share on other sites More sharing options...
Steve-Oh Posted June 30, 2015 Report Share Posted June 30, 2015 That's a lot of millimeters! Sent from Space Link to comment Share on other sites More sharing options...
Zach Posted June 30, 2015 Report Share Posted June 30, 2015 Only a little bit of rubber[emoji41]Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
